Revit MEP Forum
Welcome to Autodesk’s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
Pipe thru wall is not hidden
4 REPLIES 4
eBoesenberg
1241 Views, 4 Replies
Why are pipes that pass through walls not showing as hidden, similar to a pipe below another pipe?  What's the best way to accomplish this?
4 REPLIES 4
CoreyDaun
in reply to: eBoesenberg
I don't *think* that it's possible to force the hidden lines onto Duct or Pipe elements passing through walls or other architectural elements. Are your intentions to show the piping like this on a project-wide scale, or just for a few details or enlarged plans?
Corey D.        ADSK_Logo_EE_2013.png    AutoCAD 2014 User  Revit 2014 User
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
eBoesenberg
in reply to: CoreyDaun
I would prefer it to be project wide.  Set it and forget it.
CoreyDaun
I believe that you're out of luck here. Is it your company's standard to show the hidden lines regarding walls? I've only ever heard of anyone doing that once before, so I'm under the impression that this is uncommon enough so that the Revit design team either decided it wasn't worth the investment to cater to this need, or that they are unaware that anyone even shows MEP elements as being "hidden" behind walls and other architectural elements.
mcarroll
Has this issue been resolved?  We tend to show the pipes as hidden when passing through walls.
