It appears that when you change the insulation thickness of a pipe fitting, the sizes of the fittings change also. I have drawn a bunch of piping at the default 0" insulation thickness. I then went back and changed it all to 1.5" thickness to verify I had proper pipe to pipe clearances and all of my fittings increased in size (larger radius on elbows for example). So I tried to go back and adjust all of the pipes so that they connected to the fittings again. However, when I drag the end of a pipe over to the fitting connection point, the fitting reverts back to 0" insulation thickness. Then when I change the fitting back to 1.5" insulation, the fitting increases size again and I have to adjust the pipe again, and the process repeats itself. Please tell me I'm doing something wrong because that is ridiculous.
