Show only
Search instead for
I had a problem with medium and fine detail level. I attached my picture. How can i fix my medium detail? Do you think is it right view?
thanks,
Umit
Edited by: an_swer on Jan 13, 2009 1:18 AM
Select the Tee. Go to properties. Find the parameter called "Use Annotation Scale" and turn it off. The "single line" display will then be the same size as it is for the "model" geometry.
