Revit MEP Forum
Pipe fittings not scaling to pipe size
5 REPLIES 5
3298 Views, 5 Replies
I am placing 6" pipe, doesn’t seem to matter what type, and the elbow won’t appear larger than 1". the elbow fitting says it is 6", but only shows and measures as 1". see attached image.....
5 REPLIES 5
i figured it out..... my revit ini had a wrong setting
my LookupTableLocation was not set properly.
I currently have this same problem.  Can you walk me through this process of how to fix this?  I can't really draw any of my pipe in until i fix this problem.  Thanks.
Jrobker
Go to C:\Program Files\Autodesk\Revit MEP 2011\Program and open your Revit .INI file (notepad).
You will see the code that begins with
LookupTableLocation=
and
ENULookupTables.cab=
make sure that the paths are correct.
"It's hardware that makes a machine fast. It's software that makes a fast machine slow."
Here was the solution to my problem:
I found that in my Revit.ini file the LookUp file location line ended in the word PIPE, I just removed the word PIPE and everything works now.
That line and the ENU file location line do have to match.
LookupTableLocation=C:\ProgramData\Autodesk\RME 2011\LookupTables\
ENULookupTables.cab=d:\ProgramData\Autodesk\RME 2011\LookupTables\
Well, I did all of these and nothing happened, pipe fittings still not scaling to pipes.Except my ini file doesnt have the line ENULookup...    (but mine is 2012)
. . . and I couldnt add it because of administrator restrictions. could it be that? No further ideas?
p.s. please and thank you all.
