Revit MEP Forum
Welcome to Autodesk’s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
Pipe fittings in Course view vs. Fine view
1 REPLY 1
Warchild2114
2400 Views, 1 Reply
Revit 2013.  Our firm is trying to make the pipe fittings in Coarse view smaller than they appear.  When we switch from Fine to Coarse, they display very large in plan view and even overlap other piping fittings that are close to one another.  ie.  When I change a 1/2" pipe fitting from fine to coarse, the plan view turns the fitting into the size of a "basketball" and we would like to know if there is a setting in Revit 13 to make the corase symbols display smaller than the default setting?
1 REPLY 1
CoreyDaun
in reply to: Warchild2114
Yep. Go to Manage tab » MEP Settings ▼ Mechanical Settings, and to Pipe Setting via the navigation pane on the left. There is a parameter called "Pipe Fitting Annotation Size" in which you can globally adjust the single-line symbol sizes. Note that there is also separate parameter for "Pipe Rise / Drop Annotation Size".
Welcome to the Autodesk forums, Warchild2114!
Feel free to post any questions you may have! There are many experienced users here who generously contribute their time and effort to supporting
their peers. This is an open, peer-supported forum, so feel free to contribute any useful information or experiences to any of the topics you see here.
We hope you'll stick around a while and help strengthen the value of this community!
Be sure to review the Ground Rules, visit the FAQ Forum, and use the Search feature prior to posting a question, as it's likely been asked before.
Corey D.        ADSK_Logo_EE_2013.png    AutoCAD 2014 User  Revit 2014 User
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
Rail Community
