Still no response in another forum so I'm posting here. (My deadline is nearing).
For detail level "Medium" we would like to have straight lines for elbow pipe fittings
instead of curve.
I can't seem to lock one of the lines in the family when in a 45 degree elbow.
We would like the single line pipes look like image no 2.
Can someboby please show me how to lock the lines properly....Thanks.
Attached is your modified family. I added two additional reference planes, one vertical and one horizontal. I then drew the model line from the center point to the intersection of these planes. Each of this planes is constrained by one of the new parameters "Offset X" and "Offset Y" respectively.
CADastrophe,
Ah, reference plane. Learn something important today...Thank You!
CADastrophe,
I followed your instructions but cant seem to make this fitting work. When you get a minute could you please
tell me what I am doing wrong or not doing....Thanks
Either: 1. Start over again or 2. Delete you model lines and new Ref. Planes, change the angle to something besides 90° and choose to remove constraints. Now...
Does anyone know a quick way to modify the out-of the box REVIT copper elbow so that it displays with a straight 90 line in coarse view rather than curved line. I dont even mind if it shows tick marks at the connections. But the curved lines look horrible.
I tried just deleting the curved line and drwaing a straight line but the line does not adjust with the angle of the fitting.
Please help!
MCKLEM
