Revit MEP
Valued Contributor
Message 1 of 14 (1,642 Views)
Pipe drop/rise annotation size
1642 Views, 13 Replies
05-13-2009 11:08 AM
From reading through the forums, I understand how to change the annotation scale of pipe fittings and single line symbols. But am I correct in saying that this setting does not affect the size of the single line pipe drop/rise symbol?
Employee
martin.schmid
Message 2 of 14 (1,642 Views)
Re: Pipe drop/rise annotation size
05-13-2009 03:01 PM in reply to: bsepter
Correct.
Rise drop is:
Manage > MEP Settings > Mechanical Settings > Pipe Settings > Rise / Drop > Pipe Rise / Drop Annotation Size.
Martin Schmid, P.E.
Product Manager - Revit MEP
Architecture, Engineering, and Construction
Valued Contributor
Message 3 of 14 (1,642 Views)
05-13-2009 06:38 PM in reply to: bsepter
Just when I think I've tried everthing and clicked everything, the setting was right under my nose. Thanks Martin.
Member
ccossey
Message 4 of 14 (1,434 Views)
08-09-2011 02:04 PM in reply to: bsepter
In RevitMEP 2012, the "Pipe Rise / Drop Annotation Size" will not allow you to adjust the size below 1/8".  The rise/drop symbols in the model and on paper are way too big at that size.  Is there another way to adjust the annotation size?
Product Support
Chris.Aquino
Message 5 of 14 (1,430 Views)
08-09-2011 03:11 PM in reply to: ccossey
In 2012, the Annotation Size is tied to the Pipe Size in Project Units, which is set to round to 1/8" by default.
Go to Manage > Project Units > Piping > Pipe Size and set rounding to less than 1/8". This should fix the issue.
Chris Aquino
Technical Support Specialist
Customer Service & Support
The Revit Clinic
@Revitclinic
Member
ccossey
Message 6 of 14 (1,413 Views)
08-10-2011 05:24 AM in reply to: Chris.Aquino
That worked!  Thank you, that was frustrating...
Member
BIMQueen62
Message 7 of 14 (1,167 Views)
10-13-2011 11:47 AM in reply to: Chris.Aquino
Thanks - we where finding the same problem. In my testing I found that this works also. The problem is not knowing this when you edit Pipe Rise / Drop Annotation Size from the Mechanical Settings - work and save beyond the point of undo - then try to correct through Project Units, it is already broke and does not seem to be fixable. We know have 12" symbols for up/down on a huge VA project.
1st Question - is there a fix from this point?
2nd Question - why move a Mechanical Setting to Project Units?
Member
ccossey
Message 8 of 14 (1,162 Views)
10-13-2011 12:53 PM in reply to: bsepter
Aquino,
Did you go back and change your mechanical settings after you changed the project units?  Changing the project units just allows you go use a number less than 1/8" (or whatever you set it to) then, you have to go into mechanical settings and change the rise/drop to whatever you want it to be.  I was able to get my rise/drops to change mid-way through a project.
Hope this helps,
Cossey
Member
BIMQueen62
Message 9 of 14 (1,160 Views)
10-13-2011 12:58 PM in reply to: bsepter
Super! Yes that worked!!
Member
kvanatta
Message 10 of 14 (1,074 Views)
10-28-2011 11:54 AM in reply to: BIMQueen62
Shouldn't this method also work for pipe fittings? I can't get our fittings to look smaller.
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
