Revit MEP Forum
Pipe Tee Insulation
3 REPLIES 3
RickGraham
2121 Views, 3 Replies
Pipe Tee Insulation
Has anyone seen anything like this behavior? 4" pipes with Generic Standard tee. Add insulation - weirdness. This is Revit MEP 2014.
Rick
3 REPLIES 3
RickGraham
in reply to: RickGraham
If I switch the generic tee to something else, it is fine so I think it is in the OOTB Generic pipe tee family.
Oh, Autodesk??
Rick
CoreyDaun
This seem to be the result of an inability to create the proper geometry for the insulation. This occurs if the insulation thicker than the shoulder of the Tee, in which case it generates the generic "box" representation. See image below. The only solution I can suggest to use modify this Tee or use another with a larger "shoulder" length.
RickGraham
in reply to: CoreyDaun
Thanks Corey. Makes sense to me.
Rick
