Solved by CoreyDaun. Go to Solution.
As you mentioned, you could use a Shared Parameter:
1. Create your Shared Parameter* as a Length parameter.
2. Open the fitting family for editing and go to Family Types. (icon with four blue squares on the ribbon)
3. Under 'Parameters' click "Add...". Select "Shared Parameter", click "Select..." and choose yours from the list. Make sure that you make this an Instance parameter! Click 'OK'.
4. For this parameter, under Formula, enter the name of the parameter that defines the size. (i.e. "Nominal Diameter"). Click 'OK'.
5. Load this Family back into your Project, overwriting the previous.
6. Now, Tag the fitting (you may have to load a Tag), select the tag, and open the Family for Editing.
7. Select the Label (the text), and under Properties, click "Edit..." which is beside 'Label'.
8. Add you Shared Parameter to the list using the button on the lower left.
9. Remove all of the size parameters (if any) and add your Shared Parameter via the 'green arrow' button.
10. Select your Shared Parameter on the right pane and click the button below to set the format (Imperial Only). You can add "ø" as a suffix if desired.
11. (Imperial Only) Clear the checkbox for 'Use project settings' and check the box for "Suppress 0 feet". (I doubt you want to show the zero feet in your tag!) Click 'OK', and 'OK' again.
12. Load this Family back into you Project, overwriting the previous version.
*If you need more info on how to do this, search this forum. I know there's a lot of info on this.
Brilliant answer, works a treat! Thank you.
Now I need to work out how to do a union which is plain to threaded........don't suppose somebody has an example family they could post?
Dear Guys,
I found an easier solution. What you need to do is just go to tab: Manage/Project Units. choose discipline: Piping. then find the pipe size. remove the Unit symbol in the format. It's done.
