Hi All,
I created a Pipe Schedule and want to enter Cost in the schedule. When I enter a cost for any pipe it applies the same value to all similar Pipe Types. I want to enter different cost to different pipe sizes as it is actual.
Is there a way to either to disable auto cost entrance to all Pipe Types or change the reference to Pipe Size to apply the Cost.
Daniel Kazado
Solved by CoreyDaun. Go to Solution.
Thanks for your reply. However the cost is based on Pipe Type , and I can not give different pipe type for each size (diameter) of pipe as I use this for Routing Preferences.
The issue is when I give a cost to 2" pipe it applies to all other sizes of the same Pipe Type.
Regards
Daniel Kazado
I think the best method would be to create a Calculated Value in your Pipe Schedule that calculates the cost based on the default "Cost" parameter and the diameter, but more information would be needed to create said formula. Please explain how the costs for the different sizes would be derived, for instance if it would be a simple percentage increase to the Pipe Type's Cost based on Diameter.
Thanks for the reply. The unit price for each diameter is based on manufacturer prices and could not be calculated based on diameter or a unit price. Therefore I was not able to create a Calculated Field. The only alternative may be for each diameter to calculate the weight in a field and than calculate the price based on this weight.
In that case the same problem will be applicable for Pipe Fittings. I can not give different cost for different diameters. So I am trying to find a way to change the way cost looking when we enter. Cost looks for the Same Family and Type and copy the same cost, however I need it to look also diameter or any other parameter that I would create.
Regards
Daniel Kazado
danielkazado wrote:
"Thanks for the reply. The unit price for each diameter is based on manufacturer prices and could not be calculated based on diameter or a unit price. Therefore I was not able to create a Calculated Field. The only alternative may be for each diameter to calculate the weight in a field and than calculate the price based on this weight."
Alright, then in lieu of attempting to create a painfully complex formula, I would suggest creating a new Project Parameter (Type/Currency/Pipes) for each applicable pipe size. That way, you would be able to specify the cost for each specific Pipe Type and Size. In the Pipe Schedule, create a Calculated Value to determine which cost to report based on the Pipe's Diameter. See example below.
Parameter Name |
Value |
Cost_0.75 | 1.00 |
Cost_1.00 | 1.50 |
Cost_1.25 | 2.00 |
Cost_1.50 | 3.00 |
Cost_2.00 | 4.50 |
The following Calculated Value formula will choose the appropriate Cost Parameter based on the Pipe's Diameter:
= if(Diameter = 2", Cost_2.00, if(Diameter = 1 1/2", Cost_1.50, if(Diameter = 1 1/4", Cost_1.25, if(Diameter = 1", Cost_1.00, Cost_0.75))))
danielkazado wrote:
"In that case the same problem will be applicable for Pipe Fittings. I can not give different cost for different diameters. So I am trying to find a way to change the way cost looking when we enter. Cost looks for the Same Family and Type and copy the same cost, however I need it to look also diameter or any other parameter that I would create."
In regard to the Pipe Fittings, you could simply create a Shared Parameter within the Family and either create a formula similar to the above or add the cost listings to the Pipe Fitting's Lookup Table. Or, you could use the exact same method as you would with the Pipes above, and enter the values manually in the Project.
Don't hesitate if you have any questions or need assistance with anything!
Dear Corey,
Thanks for your reply, it was right to the point. I have 2 more questions and will appreciate if you can give some idea.
1. I want to have custom BOM (Bill Of Material) data for the same items. I included a column in Lookup Table as " BOM##text## " is this right name and how shall be the formula to call this to a Parameter. The data I will call will be something like " Welded_Elbow_DN50mm". size_lookup did not workes.
2. I want to have zone data for the items to enable quantity by zone. I made a Multi-Category Schedule but as these pipes are very selfish their zone data did not come to the table and all other items have Zone data in the schedule. Alternative1 is to select the pipes and enter ZONE value manually. Do you have any other idea to have ZONE data in the schedule. It seems similiar for the Floor data.
Daniel Kazado
danielkazado wrote:"1. I want to have custom BOM (Bill Of Material) data for the same items. I included a column in Lookup Table as " BOM##text## " is this right name and how shall be the formula to call this to a Parameter. The data I will call will be something like " Welded_Elbow_DN50mm". size_lookup did not workes."
Text does not work in Lookup Tables - I was recently trying to get that to work, too. And since Revit has no Ability to combine multiple Text Strings, something like that can quickly become an extensively long formula consisting if several levels of IF/THEN statements (attached is one of my extreme examples). If you would like to pursue this avenue, I would be happy to assist.
danielkazado wrote:"2. I want to have zone data for the items to enable quantity by zone. I made a Multi-Category Schedule but as these pipes are very selfish their zone data did not come to the table and all other items have Zone data in the schedule. Alternative1 is to select the pipes and enter ZONE value manually. Do you have any other idea to have ZONE data in the schedule. It seems similiar for the Floor data."
Pipes are not "Space/Room Aware" and therefore cannot report their location. Pipes frequently cross between more than one Space, so it wouldn't have a good way to show that on a Schedule. The only method I can suggest would be to manually enter such as value, as you said.
I was able to do all this (call space,create BOM, cost and etc.) with AUTOCAD MEP Property Set Data and export to ERP with the software I made. It came strange to me that I can not do with REVIT which shall be more BIM then AUTOCAD MEP.
Thanks that you give me information that nothing is wrong with me at least. It seems to take only quantity from REVIT and load other datas in different software will be better. I will definetly inform you if I may find any way around.
NOTE: I liked your formula it is a good job, but it is interesting that REVIT enable this formula but not combine text with a & only.
Regards
Daniel Kazado
try duplicating your pipe type but with different sizes and manually type-in the cost.
