Revit MEP Forum
Pipe Fitting - Curve 180º (problem)
3 REPLIES 3
IgBorges
961 Views, 3 Replies
I would like to create a family of pipe fitting. It would be a curve of 180 degrees.
When I create does not go as expected.
Picture attached.
Can anyone help me?
Tags (3)
3 REPLIES 3
CoreyDaun
in reply to: IgBorges
Could you attach your family file? I don't think you're going to be able to get a fitting like that to work in conjunction with the auto-route functionality.
IgBorges
in reply to: CoreyDaun
After a long time, I'm reading your reply. Smiley Wink
Unable to solve the problem. Until today!
Attach family below.
Thanks!
You need to place the connector exactly on the end surface of the pipe and make end to end connection between the pipe and the connector. You also need to check the X, Y, Z direction of the connector.
