Revit MEP Forum
Welcome to Autodesk’s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
Pipe Elbow Size Display
4 REPLIES 4
bvm76
1405 Views, 4 Replies
i have a problem with the pipe elbow not working as expected. Please see attached. Elbow size is not the same as pipe.
any help will be much appreciated!
Please mark Accept as Solution if your question is answered!
Thank You.
4 REPLIES 4
L.Maas
in reply to: bvm76
Your drawing does not give enough information to give a solution. What kind of families are you using? Are those pipes/ducts and pipe/duct fittings? Are they connected to eachother, how is the family build (parameter use)?
If you could post the families used and/or project used, forum members could have a better understanding of what is going on and give better advice.
Also, look in the default (Autodesk) libraries and look at several (elbow) families and see how they are build up.
Louis
Please mention Revit version, especially when uploading Revit files.
bvm76
in reply to: L.Maas
As per my previous post, the family in question is PIPE ELBOW and the elbow is from OOTB. I did not change any of the pipe routing preference and this is as per standard set-up when the program was installed.
Thank You.
L.Maas
in reply to: bvm76
Hi
I can not find a PIPE ELBOW family in my setup, maybe due to different libraries installed.
What might be causing the problem is that the elbow is missing its lookup-table. Many of the fittings use a lookup table which is used for sizing the family (check your PIPE ELBOW Family).
For example in my project I might use the family:"Elbow - Generic.rfa" it is in my case located in:
C:\ProgramData\Autodesk\RVT 2014\Libraries\UK\Pipe\Fittings\Generic
The lookup table: "Elbow - Generic.csv" is located in
C:\ProgramData\Autodesk\RVT 2014\Lookup Tables\Pipe
If in the family the parameter "Lookup Table Name" is empty or pointing to a wrong or non-existing lookup table the behaviour you describe can happen.
The above mentioned directories might difffer on your sytem because it might vary with Revit verisons an operating systems.
Louis
abulla
in reply to: L.Maas
You'll have to edit your Revit.ini file in order to path your lookup tables correctly.
For Revit 2013, the Revit.ini file is located here:
C:\Users\<USERNAME>\AppData\Roaming\Autodesk\Revit\Autodesk Revit 2013
For Revit 2014, the Revit.ini file is located here:
C:\Users\<USERNAME>\AppData\Roaming\Autodesk\Revit\Autodesk Revit 2014
Check the line in the ini file that points to whatever folder your lookup tables are stored.
