Revit MEP Forum
Welcome to Autodesk’s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
Pipe Accessory Family
1 REPLY 1
rafterman
1711 Views, 1 Reply
What would one use to create a valve family. I don't see an pipe fitting template like the ones for ducts. Any insight on this would be appreciated. Thank you.
1 REPLY 1
Martin__Schmid
in reply to: rafterman
Start with the Generic Model.rft. In the settings menu, click Family Category and Parameters.
Set the Category to Pipe Accessory, and try the following Parameters:
Work Plane-Based = unchecked
Always Vertical = checked
Behavior Type = Break Into
Part Type = Valve
Shared = unchecked
HTH,
Martin Schmid
Autodesk Consulting
Martin Schmid
Product Line Manager
Mechanical Detailing and Electrical Design
Architecture, Engineering, and Construction
Autodesk, Inc.
Rail Community
