I can't seem to place a Pendant Light Vertical on a sloped Ceiling.
The Help File says:
- In the Family Editor, click Settings menuFamily Category and
Parameters.
- Select the check box to enable the Always Vertical parameter.
- Click OK.
There is no such check box using OOTB Pendant Fixture.
Also because the fixture is slanted. It shows up as a 3d blob on my Reflected Ceiling Plan.
The same issus happens with 2x4 fixtures, that don't show the correct 2d representation when the fixture is not horizontal.
Also How do I place a fixture in a Room that doesn't have a defined Ceiling. For Areas such as a stairs, the lights just hang from the roof.
I get a "Don't" symbol when I try to place them.
is there a way to Place a Fixture at a height: 8 feet.
Any Help Would be appreciated
(defun botsbuildbots() (botsbuildbots))
