Revit MEP
Valued Contributor
Richie535
Message 1 of 4 (1,120 Views)
Panel Schedule Templates - Location Parameter
1120 Views, 3 Replies
06-05-2012 09:37 AM
I'm having problems with the "location parameter" in the panel schedule template.  The parameter doesn't reference correctly, and there doesn't seem to be a way to update it if the space name should change.  I've attached a screen capture of the panel schedule template.
Any suggestions?
iam4phils
Message 2 of 4 (1,111 Views)
Re: Panel Schedule Templates - Location Parameter
06-05-2012 09:56 AM in reply to: Richie535
When you are in the panel schedule, I believe there is a button to "Update Names". Either click in the cell that has the location and select "Update Names" or just select "Update Names". I believe that is going to do what you need.
Valued Contributor
Richie535
Message 3 of 4 (1,089 Views)
06-07-2012 10:25 AM in reply to: iam4phils
You cannot select the location when in the "edit panel schedule" and update the "location" parameter the same way you can update names in the cells.
CADastrophe
Message 4 of 4 (1,085 Views)
06-07-2012 10:56 AM in reply to: Richie535
Whenever a change is made to a panelboard, the schedule is updated to reflect that change. This includes, of course, modifying any of the parameters, adding a circuit, and so on. However, when the Space Name is changed, Revit does not register any actual change to the panel, even though the location data was indirectly modified. So, in order to "refresh" the schedule, you have to make some sort of change so that Revit sees a reason to regenerate the data.
Some possible methods:
  • Plan View: With the Panel Selected, edit the header or footer notes (whichever is blank) and enter a Space.
  • Plan View: Move the Panel 1" and then immediate Undo it.
  • In Schedule: Change a random parameter such as a Circuit Name and then hit Undo.
  • In Schedule: Click "Change Template" and then just click 'OK' to select the same template it already is.
I would definitely call this a bug.
***TESTED IN REVIT MEP 2012***
You are not logged in.
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
