Show only
Search instead for
I am just tinkering around with the panel schedule templates and have come across a problem. The overall width of the panel is set to 10" but the body (circuit section) is adding an extra bit of width. I tried to resize the overall width, but it keeps that same extra width. I have attached an image of the schedule as it appears when inserted onto a sheet. It looks fine in the panel schedule's view, though.
Corey D. ────────────────────────────────────────────────────────────────────── ⁞|⁞ Please use .Accept as Solution and Give Kudos as appropriate to further enhance these forums. Thank you!
