I have some pipe that's is represented as hidden below some pipe thats represented above ground. How can I change the gap to not be so large at the point where one pipe passes above the other when the hidden when the grapics display option is set to hidden?
Look in (MS) Mechanical settings. Change the inside outside gap under hidden line.
Thank you. That's exacty what I was looking for. On another note, Is there any way to change the default diameter of my pipe in a single line view. In other words, the pipe is say 2" to be run inside a wall. But the default in the single line doesn't represent it as 2" diameter and thus the pipe in the wall appears differently and the diameter extends outside of the 4" wall thickness.
No. In coarse view the thickness of the line is either determined by *hierarchy* object styles-->Model categories--> filters-->overdriven in view line weights for the pipe. If you want to show the pipe as the actual size, than you need to set your view to fine.
