Revit MEP Forum
Not Show Diameter in schedule
7 REPLIES 7
Message 1 of 8
GHASEM_ARIYANI
1364 Views, 7 Replies
Why does not represent the diameter schedule,But when I click on the field diameter, displays.
Please use " Accept as Solution", and give kudos as appropriate to further enhance these forums. Thank you!
7 REPLIES 7
Message 2 of 8
CoreyDaun
in reply to: GHASEM_ARIYANI
That's quite strange. Does it do that if you create a new Pipe Schedule? How about if you create a Pipe Schedule in a new Project File with a couple of random Pipes drawn? Does it appear the same way on any other computers?
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
Message 3 of 8
GHASEM_ARIYANI
in reply to: CoreyDaun
hi
This problem exists in all of my files.
This problem is only for Pipe.
Message 4 of 8
I suggest that you post screen captures of the Filter tab and the Sorting & Grouping tabs of those schedules. You are showing just the end result, not the settings that might be causing that result.
Licensed Architect (Florida) | Freelance Instructor | Autodesk Expert Elite (on Revit) | Profile on Linkedin
Message 5 of 8
Thank you, Mr Alfredo_Medina
But the problem I have all the files Piping.
Please see attachment noticeable
Message 6 of 8
 I had the same issue and the solution I found is ;
 In Formatting TAB
 Go to Field Format...
 Uncheck Use project settings
 Change Rounding to 1 decimal place
 Change unit Symbol to  mm
 You will see the Diameter, if you ask me why 1 decimal place and mm is needed to see it, I really do not know 🙂
Daniel Kazado
Daniel Kazado
Please use Accept as Solution if your question is answered.
You may Give Kudos if the answer is helpful.
Message 7 of 8
Yes
It is.
Many thanks for your response
Message 8 of 8
it
in reply to: danielkazado
that correct answer. We also need to uncheck " Suppress trailing 0's
