Hi;
I am beginner for the Revit MEP. I just want to draw a conduit in a floor plan which revit mep system has, but it show me this message: non of the created elements are visible in Floor plan. You may want to check the active view, its parameters and …
What is the problem here? I could not figure out..
But I tried to draw cable tray, it works..
Thanks!
Solved by julianjameson8403. Go to Solution.
Firstly I presume you are using the conduit tool and not the piping tool.
Have you checked that the conduit category is turned on i the view you are modelling conduit in?
Have you checked your view ranges are set up correctly?
Have you checked your options bar to make sure that the elevation of the conduits, etc. are within the view range of the view?
Have you checked there are no filters applied to the view which would turn off the conduit?
