Hi, I'm a beginer to lookup tables.. here I'm trying to create a custom pipe fitting that matches to the organisation standard.. i believe that i have linked the lookup tables properly to the pipe fitting.. I tested the parameters of the fitting and it changes properly in the family environment. so then i loaded the family in to the projet to test it with pipes. when i place the fitting on a pipe, the former one automatically asdjust itself to match the pipe size.. untill now there are No issues But when i try to change the pipe size along with the fitting in th eoptions bar (by tab selecting it), only the pipe size changes and the fitting doesn't change. it forms a erducer at the end..
i have attached the files for reference.. Please guide where does the mistake happen.
Solved by danielkazado. Go to Solution.
Delete the formula for Nominal Radius (default) parameter
Write the formula Nominal Radius * 2 for the Nominal Diameter (default) parameter
As the fitting connection uses Radius it works when you change pipe and fitting diameter same time.
Hope helps.
