Can you associate model text to a referance plane or something similar so that it moves and assocates itself to the new size properly?
Solved by CoreyDaun. Go to Solution.
You can constrain the boundary edges or the center axis to a Reference Plane to control the location of the element.
You can control the depth of the extrusion by linking the Depth Parameter (under Properties) to a Length Parameter in the Family..
You can control the font size by going to the element's Type Properties and linking the Text Size parameter to a Length Parameter in the Family.
NOTE: Model Text can behave quite erratically when it is rotated, or hosted to a face that rotates. It will go as far as disobeying constraints and floating off the host face. This issue was touched upon in >this< thread, where I noted that Grouping the Model Text will encourage it to adhere to dimensions better.
