Hello everyone
i have question, i have created an FCU unit, made supply and return duct connection
i want to use "model text" to write on the top of the FCU (i want to right the FCU reference number as G-02 and the model as ARG30 by using TAG option)
so at any time i want to create a callout for a machine it would directly show info direcly
and for sure it would look much better.
i tried to use it inside the MEP drawing and it is not working at all, can place it and even can use pick a plane to insert it there
and of course i cant use it while creating a family since i have more than 30 FCU and i cant create 30 different family !!
is there a way to do so ?
regards !! 🙂
Solved by CoreyDaun. Go to Solution.
Model Text in itself can be quite unstable, so I would suggest creating that as a separate Face-Based Family and then loading that into your equipment families. That way you can better constrain it, as raw Model Text will sometimes be very or utterly uncooperative.
Another possible fault with Model Text is that it cannot be blank, and if tied to a Text Parameter that is such, it won't be able to create that Type. This can be especially bad if you were to link the Model Text to an Instance Parameter that already exists in the Project - if any of those existing values are blank, then the Family will not be able to load into the Project.
When building the Model Text Family, create a new Text Parameter (Type), select the Model Text, and link it Contents to said parameter using the grey button beside it under Properties. Once loaded into the equipment family, place and select an instance of the Model Text Family and go to Type Properties. There you will be able to link the previously created Text file to a Text Parameter in the equipment Family (namely, the parameter that identifies the equipment) in the same manner as before.
My other recommendations are to create a Yes/No Parameter to control the Model Text Family's Visibility, so you can hide it if need be, and to hide the Model Text when Viewing it from the sides: Within the Model Text Family, select the Model Text and go to Visibility Graphics Overrides under Properties. In the following dialog, uncheck the boxes for "Front/Back" and "Left/Right".
I wouldn't say that it's a bad idea; you just have to be aware of the potential problems. I use Model Text in this way to label my electrical panels and the only time it would be a problem is if I wanted the Panel Name to be blank, but that situation has not arisen, yet.
