Hi
If the model is symmetric,Is it possible to mirror shaped like
Wiring - plug and ... There?
hi
Thanks for your answer.
This is my problem.
Is there a way to fix this problem?
Because so much time is wasted for a series of repetitive work.
If you happen to have a project in which the Architectural elements exist in the same model as the electrical devices, then I've found a method employing the "Mirror Project" command. While this same method can be followed while using an Architectural Link, the elements' hosting cannot be preserved, and they will become unassociated. I will explain this method further, in you're at all interested.
hi
But File architecture The link is the MEP.
