Revit MEP
Valued Contributor
davidvs
Message 1 of 2 (197 Views)
McQuay Has Manufacturer-Created HVAC Family Files!
197 Views, 1 Replies
10-17-2008 05:43 AM
McQuay has Revit 2009 family files of their HVAC equipment! These family files were actually created by McQuay.
They have features like excludable 3D clearance volumes, product documentation links, type catalog loading, and they even use shared parameters which have officially been endorsed by Autodesk for the more universal parameters (e.g. typically desirable for having on schedules). The intent is that someday in the future when other manufacturers create equipment models they can all be using the same shared parameter definitions, which should make interoperability easier.
McQuay even provides starter schedules with conditional formatting to show when values are out of range. The project files with the schedules in them also have instructions for helping you get the most out of this content.
You can get them at: http://www.mcquay.com/McQuay/BIM/Revit-BIMFiles
New Member
mowens.beallinc
Message 2 of 2 (125 Views)
Re: McQuay Has Manufacturer-Created HVAC Family Files!
11-12-2012 01:06 PM in reply to: davidvs
There appears to be a problem with the shared parameters used in certain manufacturer's family. If you try to load multiple families into a project with different shared parameter GUID the program crashes. This has occured for me while using the McQuay chiller family and a pump family (Patterson) that I've downloaded from the seek.autodesk site. I've been directed to this post http://forums.autodesk.com/t5/Autodesk-Revit-MEP/Mismatched-shared-parameter-definitions/td-p/347274... after I subbmited a support request if anyone else is having this issue.
You are not logged in.
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
