Revit MEP
Valued Contributor
%4seasons%
Message 1 of 3 (331 Views)
Accepted Solution
Material Application to Duct
331 Views, 2 Replies
08-29-2013 04:26 AM
I am trying to apply material to my duct but it seems it doesn't work. (or maybe I just miss something??) Please see attached. The shading color works fine but the surface pattern doesn't come out. Any help will be much appreciated.
*Expert Elite*
CADastrophe
Message 2 of 3 (305 Views)
Re: Material Application to Duct
08-29-2013 07:36 AM in reply to: %4seasons%
I've been able to recreate your dilemma, but I was unable to find a direct solution. It seems to me that if Material is assigned to a Duct System, the Surface Pattern will simply not be applied. I changed the Duct System to the Material "Acoustic Tile" and the grid pattern did not display, although the Duct did take on the correct image.
Now, I also tried assigning a Material to the Ducts Category via Object Styles, and that DID work. My conclusion to that is since Object Style has the lowest priority amongst all of the other overrides (e.g. View Filters, Phase Graphics, V/G Overrides), there is no override that would removing the surface pattern from the Duct.
This may be an intended function, but I wouldn't know why that would be. The only solution I can offer you is to employ a View Filter to apply a Surface Pattern to the appropriate Ducts and Duct Fittings.
Corey D.        ADSK_Logo_EE_2013.png    AutoCAD 2014 User  Revit 2014 User
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
Valued Contributor
%4seasons%
Message 3 of 3 (301 Views)
08-29-2013 07:47 AM in reply to: CADastrophe
Many thanks for the reply Corey.
I get what I want by combination of material application and V/G Filter (see attached).
You are not logged in.
Announcements
Need installation help?
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
