Revit MEP
thombrady
Message 1 of 3 (144 Views)
MEP Roof Plan
144 Views, 2 Replies
02-18-2014 05:20 AM
I want to show the HVAC Roof Equipment & I have low roofs so I have to adjust the View Range down. I figured if I had the roof plan & kept the roof box checked the only thing I would see below is roofing & anything above it. Unfortunately all the interior walls are showing up also. I know you are going to say shut off the walls, the problem is that the exterior walls also shut off & i am left with an empty shell. I have adjusted underlays, went from Plan to RCP & am running out of ideas. Again the issue is I want to look from above & see all the roofs & Equipment on those roofs & nothing else. thanks in advance
CADastrophe
Message 2 of 3 (120 Views)
Re: MEP Roof Plan
02-18-2014 09:44 AM in reply to: thombrady
Have you tried creating a Plan Region for the lower roof areas?
thombrady
Message 3 of 3 (112 Views)
Re: MEP Roof Plan
02-18-2014 10:29 AM in reply to: thombrady
Thank you, I used that before in 2012 & it did not wotk correctly or I was doing it wrong but that worked like a charm this time.
You are not logged in.
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
