Revit MEP
lotta.johannesson
Message 1 of 2 (163 Views)
Lost a dwg, where is it?
163 Views, 1 Replies
04-14-2011 07:15 AM
Hi all!
I've got a question which I can't answer, so I put my trust in to you'll. :smileyhappy:
Is there any way to see in Revit to which view/level a linked dwg is attached to? I can see in the visibility/graphics dialog that it is still in the project.....but where?
Any ideas?
Thanks in advance!
Lotta
Fell in love with Revit in 2008.
Don't forget: Kudos and Solutions!
Distinguished Contributor
Message 2 of 2 (160 Views)
Re: Lost a dwg, where is it?
04-14-2011 07:36 AM in reply to: lotta.johannesson
LJ~
I have seen linked and inserted DWG files show up in 3-D views, so you might make one of those, and expand the section box as far as you want in all six directions
However, as always, please be aware that the appearance of any object in Revit could have a dependency on other, seemingly unrelated issues, factors, objects, and force fields over which you likely have no control.  For instance, the phase of the moon, the state of the tides, the current direction of the pressure on your tectonic plate, or the location of the mothership in its orbit can are all valid visibility controls in some versions of Revit.  Those change, of course, with each release.
Best of luck
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
