Revit MEP Forum
Look-Up Table Function within an If Statement...
2 REPLIES 2
LisaDrago
1134 Views, 2 Replies
is it possible to use the size_lookup function (a lookup table) within an IF statement?
So the lookup table would only be used if certain criteria is met.
They are wanting to do this in a Duct Accessory (damper) family.
I was asked this question... i would think it could be done... but not sure.
What are your thoughts?
LD
If this helped solve your issue - remember to 'accept as solution' to help other find answers!
You can't think AutoCAD and run Revit.
Email: LisaDragoEE@gmail.com
2 REPLIES 2
CoreyDaun
in reply to: LisaDrago
Yep. "size_lookup" is just like any other function with arguments. You can set the entire function as an argument to another function...
example:
If(1=1, size_lookup(LookupTableName, LookupColumn, DefaultIfNotFound, LookupValue1, LookupValue2, ..., LookupValueN), 0')
...or you can use other conditional statements within its arguments.
example:
size_lookup(LookupTableName, if(1=1, LookupColumn1, LookupColumn2), DefaultIfNotFound, LookupValue1, LookupValue2, ..., LookupValueN)
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
LisaDrago
in reply to: CoreyDaun
Thank you @CoreyDaun - i have sent this on... We will see how it works!
LD
