Revit MEP Forum
Log Radius Elbow - anyone ever solve this?
4 REPLIES 4
LisaDrago
931 Views, 4 Replies
Hello -  I have seen the posts about the long radius elbows but really did not find an answer - so I wanted to reach out again to see if anyone has a long radius elbow - that is not flanged with a radius of 18"  as shown below?
Thanks!
LD
If this helped solve your issue - remember to 'accept as solution' to help other find answers!
You can't think AutoCAD and run Revit.
Email: LisaDragoEE@gmail.com
4 REPLIES 4
LisaDrago
in reply to: LisaDrago
I was able to find help on the AUGI forum - but thought I would post it here also for anyone looking.
Attached is the rfa and csv file.
It works great.
LD
Pabber
Is this for Revit MEP 2014 only?
LisaDrago
With what I posted - yes - I had saved it in '14 since that is what my client needed.
I can post the original component if it would help. I am not 100% sure what version it is on.
LD
LyleHardin
This is great! We use long radius elbows also.
I tried messing with the OOTB lookup table but didn't know which column to alter.
Apparently it's the last one.
Thanks!
