Solved by CoreyDaun. Go to Solution.
Thanks very much for your reply.
In a section in Revit MEP is it possible to do a similar command in AutoCAD like layer isolate and just isolate a certain group of objects? I have linked in a few files and when I create a new section I have to hide loads of things in view before I actually see what I'm looking for.
I know I can set up a template and freeze stuff but is there a quicker way?
You can try using Temporary Hide/Isolate, which is the glasses icon at the bottom of the application. After you have isolated elements and/or categories, you can click on this button and select "Apply Hide/Isolate to View" to make the change permanent.
