Revit MEP
Distinguished Contributor
Message 1 of 3 (148 Views)
Linked Room Tags
148 Views, 2 Replies
10-24-2012 08:38 AM
I have an architectural model (with rooms placed and tagged) (revit 2012).
I link this model into my project, but I can not tag the rooms.
When I turn on room fill nothing shows up.
Any idea what the issue may be?
*Expert Elite*
CADastrophe
Message 2 of 3 (145 Views)
Re: Linked Room Tags
10-24-2012 08:51 AM in reply to: spm5
Two possibilities:
1. The Rooms Category is turned off in V/G Overrides. Also check to make sure the Link's V/G's are not overridden under the Links tab.
2. The Cut Plane, under View Range, may be set to 0' - 0". If the Cut Plan does not cut through a Room, that Room will not be visible.
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
Message 3 of 3 (143 Views)
10-24-2012 08:52 AM in reply to: CADastrophe
It was a stupid mistake. The phases were not mapped properly.
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Need installation help?
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
