Revit MEP
Distinguished Contributor
spm5
Message 1 of 3 (173 Views)
Linked Room Tags
173 Views, 2 Replies
10-24-2012 08:38 AM
I have an architectural model (with rooms placed and tagged) (revit 2012).
I link this model into my project, but I can not tag the rooms.
When I turn on room fill nothing shows up.
Any idea what the issue may be?
CADastrophe
Message 2 of 3 (170 Views)
Re: Linked Room Tags
10-24-2012 08:51 AM in reply to: spm5
Two possibilities:
1. The Rooms Category is turned off in V/G Overrides. Also check to make sure the Link's V/G's are not overridden under the Links tab.
2. The Cut Plane, under View Range, may be set to 0' - 0". If the Cut Plan does not cut through a Room, that Room will not be visible.
spm5
Message 3 of 3 (168 Views)
10-24-2012 08:52 AM in reply to: CADastrophe
It was a stupid mistake. The phases were not mapped properly.
