Revit MEP Forum
Lighting fixture under staircase landing
6 REPLIES 6
moeyanung
1880 Views, 6 Replies
Does anyone know how to place face based light fixture under staircase landing??
I'm having mounting problem under staircase landing. Can't even find hosting surface by " pick new".
6 REPLIES 6
GHASEM_ARIYANI
in reply to: moeyanung
Hi
Putting the Place on Face option to choose.
If this option is not for you Click on Edit Familie
Editing environment lighting options in the Work Plane-Based enabled.
Result:
Please use " Accept as Solution", and give kudos as appropriate to further enhance these forums. Thank you!
moeyanung
in reply to: GHASEM_ARIYANI
hi gh_ar,
Thanks a lot for ur reply. Really appreciate it.
I've tried ur method. But the problem is my light fixtures are hosted families and when i pick surface of under staircase landing.. it said can't find appropiate surface to host.
in edit family, hosted family does have 'work-plane based' to check.
is there any other way to solve for hosted light fixture under staircase landing?
GHASEM_ARIYANI
Click on the link below
http://s6.uplod.ir:182/d/2k2y7m6k4hvhuf6tdcpytzdn7r2xohofvhjefh37hkeregswq4axjntu/Lighting%20fixture...
moeyanung
Hi gh_ar,
so sorry, i can't click the link. " wrong IP " message came out.
GHASEM_ARIYANI
Hi
 Install IDM(Internet Download Maneger) then Right click on the link.
Appears in the window Click on Start Download.
bvm76
try to create a reference plane with elevation corresponds to U/S of stair landing. When you insert your fixture, under PLACEMENT choose "place on work plane" and choose the reference plane you created.
Please mark Accept as Solution if your question is answered!
Thank You.
Rail Community
