Revit MEP Forum
Lighting Equipment Error
2 REPLIES 2
GHASEM_ARIYANI
315 Views, 2 Replies
hi all
When adding a light system warns Lighting Equipment.
How I solve?
What parameters should I modify?
Please use " Accept as Solution", and give kudos as appropriate to further enhance these forums. Thank you!
2 REPLIES 2
CoreyDaun
in reply to: GHASEM_ARIYANI
Your Panel is just not assigned to a Distribution System. Select your Panel and a pull-down will appear on the Options Bar (just below the Ribbon) which will allow you to select a valid Distribution System based on the data of the Primary Electrical Connector of the Panel. By default, newly placed Electrical Equipment is not assigned to a Distribution System, so this must be done manually.
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
GHASEM_ARIYANI
in reply to: CoreyDaun
Thank you CADastrophe.
