Revit MEP Forum
Licensing Revit MEP 2012
3 REPLIES 3
pcjdavidmoore
448 Views, 3 Replies
I'm new to Revit. I work for a small plumbing company and a project we are working on requires BIM cordination and 3D shop/as-built drawings. The engineer and general contractor are using Autodesk Revit 2012. I downloaded a trial of Revit MEP 2012 and it's working well, but I'm unable to find where I can obtain a license for the software and activate it. I downloaded a trial of Revit 2014, but it converted the job files to a new version and created errors.
Where can I obtain a license for Revit MEP 2012?
Thanks in advance.
3 REPLIES 3
DarrenP
in reply to: pcjdavidmoore
its not free
you need to buy a license from a local autodesk reseller: http://usa.autodesk.com/adsk/servlet/ps/searchform?id=1088201&siteID=123112
DarrenP
CoreyDaun
Also, be aware that any and all of the files that have been converted to the 2014 format can no longer be opened in previous versions of Revit - there is no backwards compatibility in Revit.
pcjdavidmoore
in reply to: DarrenP
Thanks for the quick response. I'm looking into local resalers now.
