Revit MEP Forum
Levels in Revit
4 REPLIES 4
Ihab-b
567 Views, 4 Replies
Levels in Revit
Hello
i have a question about adding levels in Revit MEP
i open Mechanical template and when i add levels it only shows in Mechanical Discipline and i can only create floor plan view in Mechanical Discipline
when i open Plumbing elevations it shows the levels but i can't create a floor plane view for the new levels in Plumbing Discipline
i only can do it if i uncheck the ( do not duplicate exiting views ) box
how i can make floor plan view for the new levels in Plumbing Discipline without duplicating the view ???
or i should dublicting the view and change the discpline from properties ???
4 REPLIES 4
L.Maas
in reply to: Ihab-b
That is what I would do. Duplicate your new view and change its properties (and assign new viewtemplate if needed).
Louis
Please mention Revit version, especially when uploading Revit files.
Ihab-b
in reply to: L.Maas
is there anything i can do to make Revit create floor plan view for both Mechanical and plumbing discipline ???
L.Maas
in reply to: Ihab-b
Do not think so. You would have to resort to programming, using the Revit API. However your best option would be to use project templates. Take one time to prepare a good template with (if needed) many levels and many views and you can reuse it in future projects.
Louis
Ihab-b
in reply to: L.Maas
making a template is the best option
thank you
