Revit MEP
Member
Message 1 of 4 (524 Views)
Latest revision per sheet only!
524 Views, 3 Replies
09-03-2012 03:34 AM
the problem is I have El and VVS and I have 1 revision on VVS and 3 on El. Is there a way to have the latest and only the latest revision on a sheet but still maintain the information of past revisions on the sheet.
  1. If I ‘hide elements’ of the revision cloud to leave only ‘revision C’ then the information disappears in the title block
  2. If I turn off the revision clouds in the ‘sheet/revision’ control then it will hide all A in the project, (even if it has been selected per sheet, not project.
Should I make a different sequence of revisions per ‘trade’?? any ideas?
Active Contributor
tjbeecher
Message 2 of 4 (509 Views)
Re: Latest revision per sheet only!
09-03-2012 08:17 AM in reply to: chpf
Go under view, click revisions under sheet composition.  The last column is called show.  There you can change which ones will show and wont show.
Member
Message 3 of 4 (482 Views)
09-04-2012 06:46 AM in reply to: tjbeecher
Thankyou for your help! Yes I knew we could do this... the problem was that eg. revision A for the vvs and el was under the say sequence, so when you turned it off it turned it off in the whole project not just the one 'trade' which is what we wanted... what we did was break up the revision sequences into 'trades' so that helped. Thanks again.
*Expert Elite*
CADastrophe
Message 4 of 4 (479 Views)
09-04-2012 06:59 AM in reply to: chpf
I believe that this is a bit beyond the simple capabilities of Revit. You cannot make a separate Issuance for each discipline and still have it display the same Revision Number for all disciplines. Have you considered making the information on the Title Block static text in lieu of the Revision Schedule?
Welcome to the Autodesk forums, chpf!
Feel free to post any questions you may have! There are many experienced users here who generously contribute their time and effort to supporting
their peers. This is an open, peer-supported forum, so feel free to contribute any useful information or experiences to any of the topics you see here.
We hope you'll stick around a while and help strengthen the value of this community!
Be sure to review the Ground Rules, visit the FAQ Forum, and use the Search feature prior to posting a question, as it's likely been asked before.
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
