Revit MEP
Valued Contributor
Message 1 of 4 (270 Views)
Accepted Solution
Keynote questions
270 Views, 3 Replies
06-09-2012 06:32 PM
I have two questions..
1. How can I add an underline? I need to underline some words in the line.
2. How do I create a two/three line keynote? I need to break the note so that I can
    fit it in a space in a crowded sheet..
Thanks in advance.
Valued Mentor
julianjameson8403
Message 2 of 4 (258 Views)
Re: Keynote questions
06-11-2012 03:22 AM in reply to: EddieFromDC
As the Keynote files are txt files I doubt you can provide any type of formatting.
For multi lines - are you using the keynote numbering or the keynote text?
If using the numbering (probably a simpler way to deal with it) then the schedule in the sheets can be customised in width.
If using the text then the only real way wuold be to have several different types of keynote tag which have different label widths. This means having say five version of the lable in one tag with different visibility for each one dependent upon the type. i.e 10mm wide, 25mm wide, etc The width of the parameter can be estimated using lines offset from the reference planes and then dragging the grips of the label to align with the lines.
Personally, I would use numbers and then schedule the numbers automatically on the sheets with a keynote legend.
If my reply answers your query, please use the Accept as Solution.
Please give Kudos as appropriate to enhance the value of these forums.
Thank you!
Valued Contributor
Message 3 of 4 (240 Views)
06-11-2012 04:22 PM in reply to: julianjameson8403
julianjameson8403,
We use keynote text. Thank you for your response. I will look into that.
New Member
Message 4 of 4 (161 Views)
08-25-2012 04:58 AM in reply to: EddieFromDC
Everyone says this is impossible but in fact it  is possible. If you right click on your text file and do an Open With...Excel you can edit with excel and add line breaks using alt+return. Make sure to save as a tab delimited text file. This will not work if you tryd ata use the import data function in excel,so you must continue to edit the file in notepad or in the manner just described. Unfortunately even the excellent and useful Keynote Manager drops this special, secrete line break encoding. If anyone knowhow hat this character code is or how to pass it on on notepad or Kenote Manager I would love to know.
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
