Hi guys,
I have linked in an IFC model in REVIT Mep. The building is just a basic 2 storey community hall with offices/toilets/changing rooms & a recreation hall.
I have created the spaces with no issues on all the rooms except the recreation hall. The recreation hall goes from the ground floor level & extends above the second floor level & covers the extents up to roof level. Its just a regular recreation hall as in most community centres or school gyms.
The issue I am having is every time I place a space I get a warning message up saying I have placed the space where multiple spaces are already, I have deleted these additional spaces but I am still getting the same warning message. I can click ok on the warning box & will place the space but only up to first floor level.
I then proceed to create an offset that will raise the space 2 metres above first floor level & then I get a 'geometry cannot be cut' warning box.
I have tried for about 5 hous today trying as much as I can & its the last room on the model I needed to complete before I could start the energy analysis ! Any help is much appreciated.
I will try get an attachement tommorow when I am back in work
Cheers
Solved by dutch1. Go to Solution.
