Revit MEP
New Member
mike
Message 1 of 3 (228 Views)
Issue with conduit runs and schedules
228 Views, 2 Replies
01-08-2014 06:55 AM
I am having an issue with conduit runs and schedules.  If I create a conduit run, then select the each object in the run and use the "Change Type" icon from the Edit panel of the Modify tab and change the selected conduit run type to a different type, the revised conduit run will not appear in a conduit run schedule.  I am having this issue in 2013 and 2014.  Is this a glitch in Revit or am I missing something?  Thanks for your help.
CADastrophe
Message 2 of 3 (207 Views)
Re: Issue with conduit runs and schedules
01-08-2014 12:18 PM in reply to: mike
Hi Mike, welcome to the Discussion Groups!
I'm not sure if that is a bug or what. Also, instance parameters (such as Comments) get reset and the data erased. I was able to get the Conduit Run to reappear in the Conduit Run Schedule by selecting a single segment of Conduit (after using the Change Type command), changing the segment's Type via Type Selector to anything else, and then changing it right back again.
New Member
mike
Message 3 of 3 (202 Views)
01-08-2014 12:30 PM in reply to: CADastrophe
Corey,
Great tip.  Your suggested work around takes care of the immediate need.  I sure appreciate your help.  Thanks!
Mike
You are not logged in.
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
