Revit MEP Forum
Welcome to Autodesk’s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
Inserting Lights
1 REPLY 1
rjones
296 Views, 1 Reply
Inserting Lights
When I insert lights into the model they show up dark on the ceiling plan but when I switch over to the floor plan they show up light in color and below furniture. How do I fix this?
1 REPLY 1
CoreyDaun
in reply to: rjones
It sounds like the Floor Plan View is set to either the Architectural or Coordination discipline, which is set under the View's properties. Switch this to Electrical. If this value is set to Mechanical or Electrical, the visibility of all out-of-discipline elements (i.e. walls, furniture) becomes faded and transparent.
Corey D.        ADSK_Logo_EE_2013.png    AutoCAD 2014 User  Revit 2014 User
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
