Good idea, I'll give that a try.
John
"Scott Davis" wrote in message news:5751702@discussion.autodesk.com...
well, you can link the XLS into AutoCAD, and then link thw DWG into Revit.
"John Henry" wrote in message
news:5751602@discussion.autodesk.com...
This probably isn't the best way, but I create a PDF from excel, then I save
the PDF as JPG in Photoshop, which I then drag into
Revit. It doesn't give a real clear image but it works.
I would like to hear other suggestions too.
John
wrote in message news:5751450@discussion.autodesk.com...
does anybody know the way to get an excel spread sheet on a view in revit.
I need to display my ventilation calculation which are
in excel files. I have tried to put them into autocad first and then import
them into revit but the resolution gets messed up and
you cannot read them. Can anyone suggest a better way.
thanks
