Revit MEP Forum
Importing ang Exporting Schedules to Revit
9 REPLIES 9
Message 1 of 10
bluelion
5178 Views, 9 Replies
Is there a way of importing the TXT or XML file back into Revit once changes have been made to the schedule?
ATM I only seem to be able to export my schedules but have no way of brining them back in.
Todd Barry (Mechanical Design Engineer)
Sydney, Australia
Mob: 0438 479 967
E: tbarry@fredon.com.au or toddbarry7@gmail.com
9 REPLIES 9
Message 2 of 10
CoreyDaun
in reply to: bluelion
That is correct. Revit's Schedules are a live report of the data gathered from the elements in the Project Model, so you couldn't just be able to import a schedule as a Revit Schedule. If you wanted to bring in an outside schedule, I believe that the best method would be to create the schedule in a .dwg file and then link that into your Revit Project in a Drafting View. An imported OLE object will not come through in Revit.
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
Message 3 of 10
bluelion
in reply to: CoreyDaun
thought maybe it would be similar to creating type catalogs.
Oh well I guess its not to be lol
Sydney, Australia
Mob: 0438 479 967
Message 4 of 10
bluelion
Once you put the objects in the drawing I though maybe it would be possible to change shared Parameters in a remote spread sheet similar to type catalogs and look up tables I guess.
Whats the issue with not being able to do this?
Sydney, Australia
Mob: 0438 479 967
Message 5 of 10
SashKaz
Hi Todd,
There is a way to export your schedule data to a Excel document, make changes within the Excel document, and then pull that data back into Revit. The add-on that you want to look into is Ideate BIMLink.
I have provided a link to the BIMLink website. You should have a look at it and check out some of the Youtube videos as well so that you can see a demonstration of how it works. It is a very powerful program that can save you a lot of time with your schedule edits.
http://www.ideatebimlink.com/
If you have any questions, please let me know. I am more than happy to help!
Sash Kazeminejad
Message 6 of 10
bluelion
in reply to: SashKaz
Thanks SashKaz, I will definately look into it. If this wroks you are a legend 😉
Sydney, Australia
Mob: 0438 479 967
Message 7 of 10
SashKaz
Todd,
Please let me know if you have any questions. BIMLink is a powerful add-in and works extremely well. The website and Youtube videos will give you a good idea of what it can do.
Sash Kazeminejad
Message 8 of 10
thanks
Message 9 of 10
atticus.borrie
SashKaz,
Do you know if it is at all possible to export URL type Parameters to excel from this tool or any others?  I have been using the free BIMone tool (Link below) to export data, edit and import back into the Revit model.  Works really well for everything except URL type parameters.
https://apps.autodesk.com/RVT/en/Detail/Index?id=6290726048826015851&appLang=en&os=Win32_64
Message 10 of 10
SashKaz
in reply to: atticus.borrie
Hi @atticus.borrie,
Yes, Ideate BIMLink WILL export URL data and custom parameters to Excel so that you can edit in excel and import back into the Revit model.
Hope this helps
SashKaz
