Revit MEP
Active Contributor
bluelion
Message 1 of 7 (1,056 Views)
Importing ang Exporting Schedules to Revit
1056 Views, 6 Replies
07-08-2013 05:28 PM
Is there a way of importing the TXT or XML file back into Revit once changes have been made to the schedule?
ATM I only seem to be able to export my schedules but have no way of brining them back in.
Todd Barry (Mechanical Design Engineer)
Sydney, Australia
Mob: 0438 479 967
E: tbarry@fredon.com.au or toddbarry7@gmail.com
CADastrophe
Message 2 of 7 (1,018 Views)
Re: Importing ang Exporting Schedules to Revit
07-09-2013 05:09 AM in reply to: bluelion
That is correct. Revit's Schedules are a live report of the data gathered from the elements in the Project Model, so you couldn't just be able to import a schedule as a Revit Schedule. If you wanted to bring in an outside schedule, I believe that the best method would be to create the schedule in a .dwg file and then link that into your Revit Project in a Drafting View. An imported OLE object will not come through in Revit.
Active Contributor
bluelion
Message 3 of 7 (1,005 Views)
07-09-2013 01:02 PM in reply to: CADastrophe
thought maybe it would be similar to creating type catalogs.
Oh well I guess its not to be lol
Sydney, Australia
Mob: 0438 479 967
Active Contributor
bluelion
Message 4 of 7 (981 Views)
07-09-2013 11:01 PM in reply to: CADastrophe
Once you put the objects in the drawing I though maybe it would be possible to change shared Parameters in a remote spread sheet similar to type catalogs and look up tables I guess.
Whats the issue with not being able to do this?
Sydney, Australia
Mob: 0438 479 967
Member
SashKaz
Message 5 of 7 (929 Views)
07-24-2013 07:32 AM in reply to: bluelion
Hi Todd,
There is a way to export your schedule data to a Excel document, make changes within the Excel document, and then pull that data back into Revit. The add-on that you want to look into is Ideate BIMLink.
I have provided a link to the BIMLink website. You should have a look at it and check out some of the Youtube videos as well so that you can see a demonstration of how it works. It is a very powerful program that can save you a lot of time with your schedule edits.
http://www.ideatebimlink.com/
If you have any questions, please let me know. I am more than happy to help!
Sash Kazeminejad
Active Contributor
bluelion
Message 6 of 7 (916 Views)
07-24-2013 12:42 PM in reply to: SashKaz
Thanks SashKaz, I will definately look into it. If this wroks you are a legend :smileywink:
Sydney, Australia
Mob: 0438 479 967
Member
SashKaz
Message 7 of 7 (904 Views)
07-24-2013 09:36 PM in reply to: bluelion
Todd,
Please let me know if you have any questions. BIMLink is a powerful add-in and works extremely well. The website and Youtube videos will give you a good idea of what it can do.
Sash Kazeminejad
You are not logged in.
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
