You need to copy/monitor the elevation grids, than create the new views.
the first and second floors are default views, you'll get that in a new drawing.
go to an Elevation and select copy/monitor-->select link-->copy (in your copy monitor options)-->multiple-->select elevation grids-->finish-->finish mode.
After you have done this go to VIEW-->new floor plan and you will see the levels you copied.
"It's hardware that makes a machine fast. It's software that makes a fast machine slow."
