We tried to import a ifc type file (our client uses archicad) into Revit MEP but got "...not able to join elements..." error messages.any one outthere experienced this before? your help is most appreciated.
Solved by embolisim. Go to Solution.
Solved by alan.quinn. Go to Solution.
Sorry, I have no experience with third party applications but if you look through the following links I'm guessing you'll find some information that will help.
Using Information from Other Sources
http://wikihelp.autodesk.com/Revit/enu/2012/Help/Revit_User's_Guide/0066-Start_a_66/0072-Using_In72
Or
Thanks for posting.
Make sure you are using the IFC import tool available for free download from the Graphisoft website.
http://www.graphisoft.com/support/archicad/downloads/interoperability/
It really does improve the quality of the import.
Also, install Solibri viewer (its java & runs in your browser so you can install it without admin priveledges) and use it to view the raw IFC model so you can see what is missing.
Accept that hundreds of error messages is normal when importing IFC files. I always save the error file and review it, because I'm a sad pathetic looser with nothing better to do.
Most of the errors are things like overlapping walls that dont make much difference to what you are doing.
Sometims things that should cut other geometry dont form the cut, so look out for that. Door hi-lights is a common one, they end up embedded in the wall.
Ceilings wont show the tile grid. I always ask for dwg files as well & link them in to define the tile set out.
hth
Thank you Emobolism! the issue got corrected by the client who cleaned the model before translating into IFC format.
