Revit MEP
carriehall42
Message 1 of 10 (229 Views)
I want to schedule this
229 Views, 9 Replies
06-12-2012 09:41 AM
Please see picture. I know this is easier than I am making it out to be, but i haven't figured it out yet.
Carrie
Message 2 of 10 (222 Views)
Re: I want to schedule this
06-12-2012 10:12 AM in reply to: carriehall42
Is that "CFM" Parameter linked to the duct connector element's "flow" parameter inside the family?
carriehall42
Message 3 of 10 (219 Views)
06-12-2012 10:17 AM in reply to: rocky1717
It is now, but it is still different than the system flow. If I change the flow of one of the diffusers, it updates the system flow but not the cfm in the schedule. Should I be scheduling a system? Is that even possible?
Message 4 of 10 (211 Views)
06-12-2012 10:37 AM in reply to: carriehall42
Make sure the mechanical setting for the duct connector look like this.
Message 5 of 10 (208 Views)
06-12-2012 10:42 AM in reply to: carriehall42
Post a pic of your schedule.
carriehall42
Message 6 of 10 (202 Views)
06-12-2012 11:43 AM in reply to: rocky1717
Here it is
Valued Mentor
julianjameson8403
Message 7 of 10 (194 Views)
06-12-2012 01:47 PM in reply to: carriehall42
Is the parameter in the family a shared parameter?
If so, did it come from the same source as the CFM parameter used in the other families?
Looking at your picture - you have the connector set as calculated and bidirectional. It should be preset and in as Rocky mentions.
Also I would add a loss value in the families - even if a notional value thus removing errors in your model.
Also good practice is make sure you name your connectors.
If my reply answers your query, please use the Accept as Solution.
Please give Kudos as appropriate to enhance the value of these forums.
Thank you!
carriehall42
Message 8 of 10 (190 Views)
06-12-2012 02:05 PM in reply to: julianjameson8403
Yes the parameter is a shared parameter. If it were a family parameter I wouldn't be able to schedule it. Also this is the first time I am using this, (In previous projects, I didn't have time to figure all this out so schedules were done in AutoCAD) so I don't have it in other families yet.
I have now set the connector to preset and in as you (and Rocky) mentioned, but technically this air is supply so wouldn't it be "out"? And I will name my connector. I usually do anyway.
With these changes, My unit has 2125 cfm which should be the same for the system, however the system added up all the cfm for each diffuser and the cfm for the unit for a total of 4250. The system is supposed to have 2125 cfm as well.
Distinguished Mentor
asommer
Message 9 of 10 (183 Views)
06-12-2012 02:19 PM in reply to: carriehall42
Edit the System, select that unit as the "Equipment" for the system.
Also, the Supply Duct Connector in that equipment family should be Supply, OUT, and Calculated.
carriehall42
Message 10 of 10 (179 Views)
06-12-2012 03:17 PM in reply to: asommer
WooHoo! I got it to work. Setting the Supply Duct Connector to  Supply, OUT, and Calculated did the trick!
Carrie
You are not logged in.
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
