Revit MEP Forum
Welcome to Autodesk’s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
How to mirror model lines in a 3D object?
1 REPLY 1
Mehdi.Kardehi
465 Views, 1 Reply
I want to mirror the model lines I have drawn on one face of this machine to the other size...but when I select them and I change my view to pick mirror axis I can't do it as the selection get missed... Any help?
Model lines are inside that red thing I have attached
1 REPLY 1
ajax05k
in reply to: Mehdi.Kardehi
After selection of lines you can save the selection set, so that in future when you want that selection set you can have it. For this select all the lines-> click on save-> [which is beside the filter ribbon] give some name to it, thats it now you can load the selection set whenever you want
Ajay K. HVAC Designer, BIM Modeler
