I want my supply duct to be galvanized grey but my flex to be black...is there a way to do that? both are in supply air system
Cheers,
M
Solved by CoreyDaun. Go to Solution.
Solved by ajax05k. Go to Solution.
I believe that your only option is to create a View Filter that applies to the Flex Ducts Category. If you wish, you can configure the Filter Rules to "System Classification" "contains" "supply" to specifically target the Flex Duct from that System, or you can leave the Filter Rules blank to target all Flex Duct. Once you had established this and added it to the appropriate View(s), set the Fill Pattern Overrides to "Black" and "Solid Fill". This Filter will have to be added to each View as need or included in your View Template(s).
Edit: Ajay beat me to the response...
Regarding his #1: This is a good way to affect only select Flex Duct Types, but if you wish to affect all Flex Duct period, then leave the Filter Rules blank.
