Revit MEP Forum
How to find xyz coordinate values of the pipes and other objects
3 REPLIES 3
naym_rm
3416 Views, 3 Replies
Hi
I am new in Revit. I need to know the coordinate of different places in revit document. Also need to check the pipe object end points.
I get an option which shows E and N values. But how do I get coordinate like autocad.
Regards
Naym
Tags (2)
3 REPLIES 3
AJA14
in reply to: naym_rm
Hi, the east is the X and the north is the Y.
The spot coordinate can also show the Z. select the tag and change the type from the selector to spot with elevation. If you don't find it, edit the type and click the checkbox for the elevation.
NOTE: You can also make revit display X in place of E and Y in place of N.
Ali Al-Hammoud
Structural Design Engineer
MZ & Partners Engineering Consultancy
M.Maarleveld
in reply to: AJA14
Can you use the xyz coordinates in a calculated value? I can only find them in Revit with spot coordinate or BIMLINK,  Is there any other way?
Maarten Maarleveld
GlynnisVP
in reply to: M.Maarleveld
I don't believe you can obtain the XYZ data from Revit itself though perhaps the ODBC method might work?
Here's a short video showing the pipe coordinate data via Ideate BIMLink, FYI.
http://www.screencast.com/t/n5UOR2D03dfw
Best Regards,
Glynnis Patterson
www.ideatesoftware.com
